Brief Description: Elevator priming & gear leg intersection fairings
In the morning I applied primer to the elevators. After lunch I began fitting the gear leg upper intersection fairings. I started with the right gear then moved to the nose gear before breaking for dinner. After dinner I masked the elevators some more and applied UV blocker to the elevator fairings.
Elevator primer applied
Right upper gear leg intersection fairing fitted
Nose gear leg intersection fairing fitting started
